Hello Chris,
1- Typical static power model
i- When the typical static power model will be available?
Ans: Please refer here Table 23
ii- access to pre-release model
Ans: All the E-series power model is updated in 26.1
2- Power and Thermal Analyzer on empty design
i(a)- design use no DSP or RAM blocks
Ans: This is expected. Even no DSP or M20K blocks instantiated, the silicon physically contributes leakage/static power.
i(b)- Which fabric component draw power significantly
Ans: clock input buffer, Global clock, configuration related circuitry, SDM, default termination, unused IO bank static leakage etc.IO is only one part of the contributors.
i(c) - what is included in miscellaneous category?
Ans: SDM related circuit, Configuration circuit, Device management logic, power-monitoring circuit(POR), temperature/voltage sensing circuit, etc.
3- Can HPS and transceivers by fully powered down by disconnecting the power rails?
Ans: Basically yes, but why? you can choose device variance without HPS and without transceiver if you dont want this feature. This variance comes without HPS and transceivers.
regards,
Farabi
- KJ12 days ago
Hi Farabi,
Thank you for your answers. They are very useful.
With regards to power consumption of uninstantiated DSP and M20K blocks, the report shows they also contribute to dynamic power consumption, as opposed to just leakage power. Could you clarify why?
With regards to powering down HPS/transceivers, choosing the part that doesn't have those in the first place would be ideal, but not all fabric sizes for Agilex 5 E come with that configuration option, unfortunately.
Chris
- Farabi_Altera8 days ago
Hello Chris,
1- Power analyzer partitions device power into categories. Some infrastructure power may be allocated to DSP or RAM category even though no DSP arithmetic or memory read/write activity is occurring.
2- Even individual blocks are power-gated, the surrounding clocking and infrastructure networks still exist on the die. The analyzer may distribute a portion of this activity into DSP/RAM categories.
3- Power Analyzer includes small baseline dynamic values to account for device-level activity that cannot be cleanly assigned elsewhere. In nearly empty design, these baseline values can appear in the calcualtion.
regards,
Farabi - Farabi_Altera6 days ago
Hello Chris,
Do you have further question?
rgards,
Farabi
