Hello Kian,
Thank you for your response.
- It is revision C. However, it seems I've been referring to the schematics of rev b all this time. I could find only rev b schematics on the Terasic website. Could direct me to where I could find data on rev c boards?
- I wrote a c code for toggling the GPIO and probed the R306, however, there's no change. It doesn't toggle. It stays high.
- When scanning the i2c bus, I see 0x53 which is the g-sensor since that is its device address. I don't see LTC connector.
Hi greenlantern01,
Regarding the GPIO toggling not working , probably you can check whether R306 is the same placement as per rev C. Unfortunately i dont have Rev B schematic so cannot confirm on this whether the connections are the same with Rev C.
Probably you will need to toggle the LTC first before can use the i2cdetect.
Kian
- greenlantern0114 days ago
Hi Kian,
The board I am using is Rev C. I have tried doing the following steps to be able to toggle the HPS_LTC_GPIO:
- Verified the HDL file connections.
2. Checked the Pin Planner to confirm if I am connecting to the correct I2C bus.
3. I generated the rbf file from the sof_to_rbf generator and saved it on the memory card which has angstrom on it.
4. I have attached the C code that I used to toggle the HPS_LTC_GPIO.
5. i2cdetect -l output:
6. i2cdetect -y -r 0 output:
I have shared the DTS file changes previously, however when trying to boot the FPGA after those changes the FPGA crashes.
Despite these process I am still not able to toggle. Kindly advice on next steps.
