AreYouLoco
1 year agoLantiq Falcon SoC: FALC ON-S EASY98035ET SDK&documentation request
I am reposting here as i structed by @pujeeth: Hi, I requested source code (SDK) of SoC mentioned in the subject from the producer of the end product: HALNy. The exact model of the end product is:...
ManoranjanDas
1 year agoHello AreYouLoco,
Greetings from the day!
Regarding your query, please provide the following details to proceed with this case:
Could you please confirm which product and document you are referring to?
If you are observing any additional issues, please share them with us. We are happy to assist you.
Thank you for choosing Intel products and services.
Manoranjan.
Intel Customer Support Technician
AreYouLoco
1 year agoHi Manoranjan,
I am reffering to https://halny.com/portfolio/hl-gsfp/ module it runs on Lantiq Falcon EASY98035ET SoC. As I stated many times previously. The issue that I have is UART pins are connected to TX_FAULT and LOS pins on SFP. So periodically I encounter link loss. I am looking for a way to disable those two GPIO pins loosing uart access anyway done in a stupid way against GPON specification.
Additionally TX_FAULT and LOS are signal inverted. But this has been worked around by kernel developer RMK. Another issue worked around is EEPROM of that module doesnt advertize 2,5GBps.
I hope this give you a good overview of what I am trying to fix.
