I have run the
msim_setup.tcl
and then switch to my
TB_ADC_to_Parallel_run_msim_rtl_vhdl.do
file same result.
is this possible with the Quartus Prime Light /Quasta Altera Starter version?
Sorry for the late reply.
When I checked the TB_ADC_to_Parallel_run_msim_rtl_vhdl.do file, I noticed that its content is incorrect:
vlib ADC_to_Parallel vmap ADC_to_Parallel ADC_to_Parallel vlog -work ADC_to_Parallel +incdir+d:/quartus/tb_adc_to_parallel_vhdl/db/ip/adc_to_parallel {d:/quartus/tb_adc_to_parallel_vhdl/db/ip/adc_to_parallel/adc_to_parallel.v} ]
If you have already run the msim_setup.tcl script, you only need to proceed with commands like dev_com, com, etc. You may refer to the documentation for further details: https://docs.altera.com/r/docs/683870/25.3.1/quartus-prime-pro-edition-user-guide-third-party-simulation/questasim-simulation-setup-script-example
3.4. QuestaSim Simulation Setup Script Example
