Thanks a lot for the reply. But, why do we need USB PHY in Agilex M FPGA based board. To program, MAX10/Agilex, JTAG interface will provide. But,what extra functionality that USB Interface provides in the board ?
Thulasi
Hi Thulasi,
After checking the connection, we determine that is USB to JTAG which it is for the on-board USB blaster II.
Aqid
- Thulasi16 days ago
1. Why do we need to provide both a JTAG header and a USB connector (along with its supporting circuitry) for JTAG access?
2. Can we eliminate the USB circuitry and provide only the JTAG header?
3. Alternatively, can we remove the JTAG header and retain only the USB connector and its associated circuitry?
4. Why is an on-board USB-Blaster II required? Wouldn't a standard JTAG header alone be sufficient for programming and debugging?
Thulasi
- AqidAyman_Altera14 days ago
Hi Thulasi,
As an evaluation kit, we want to provide both JTAG experience to the customer. However, it is dependent on your requirement to not use the USB circuitry but please ensure you have the USB Blaster IP in order to use JTAG from USB connector.
Aqid
