anonimcs's avatar
anonimcs
2 years ago
Enable on-chip termination for Differential Transceiver clocks
Hi all, I was wondering what .qsf assignments I would need to enable on-chip termination for my differential transceiver clocks. The target device is an Arria10. When I tried using the line below, I...
  • FvM's avatar
    1 year ago
    as far as I understand you are still searching for valid .qsf entry for transceiver clock input termination.
    Valid settings are listed in this document: https://www.intel.com/content/www/us/en/docs/programmable/683296/24-3.html
    As far as I see, the settings are the same for previous Quartus Pro versions.
    The option for transceiver reference clock termination is XCVR_A10_REFCLK_TERM_TRISTATE
    allowed values are TRISTATE_OFF and TRISTATE_ON
    TRISTATE_OFF corresponds to 100 ohm differential termination.
    Some confusion is caused by the fact, that Quartus Std. uses a different option name
    XCVR_REFCLK_PIN_TERMINATION
    values are AC_COUPLING, DC_COUPLING_EXTERNAL_RESISTOR and DC_COUPLING_INTERNAL_100_OHMS
    See: https://www.intel.com/content/www/us/en/docs/programmable/683084/current/settings-file-reference-manual.html
    To check which termination has been actually implemented, you can review QPP fitter report/Plan Stage/Input Pins.
    Frank
