slehNew Contributor2 days agoAvalon-ST configuration with Agilex 3 fails Hi, I have implemented a kind of passive serial programming from a CPU using SPI and a shift register. The signals nSTATUS, nCONFIG, CONF_DONE, READY, and VALID are directly controlled by GPIOs. Thi...Show More
slehNew Contributor to sstrell1 day agoLet's hope it works this time.2_3_restart.png58 KBfull_timing.png51 KB4_start.png63 KBfull_timing_orig.png59 KB2_start.png64 KB
Recent DiscussionsSystem PLL of Agliex5 PCIE example design cannot be locked after configurationBidirectional differential port on MAX10Quartus Pro invalid command name "End-trace"SolvedGTS Transceiver CompatibilityBackplane Ethernet 10GBASE-KR PHY FPGA IP
