LLCC
2 years agoarria 10 lvds serdes
hello, I was originally using the quartus 17.1 Standard Edition to complete some designs that include LVDS SERDES IPs, and the projects were able to pass compilation successfully. However, when I mi...
AqidAyman_Altera
2 years agoHello,
Can you try to regenerate the Altera LVDS SERDES Receiver IP?
Or else, you can try to connect them up in your design.
LLCC
2 years agoThank you. I have already solved this problem. My feeling is that when the data output by this IP is being processed logically, it requires data from all channels to be used together. For example, if I only use the output data from a single channel to complete a certain logical process, while the output data from other channels is used for another logical process, it may trigger the aforementioned error.
