AGFB014R24B2E3V Agilex hanging during Linux boot
May I know how did you change for "Updated memory reg property to allocate 4GB instead of 8GB" ?
In the u-boot-board.dtsi file (the file is available in requested_files.zip from an earlier post), I have the following settings for the 4GB memory:
memory {
#address-cells = <2>;
#size-cells = <2>;
reg = <0 0x00000000 0 0x80000000>, /* 2GB */
<2 0x80000000 0 0x80000000>; /* 2GB */
u-boot,dm-pre-reloc;
Thanks!
- letmein4 years ago
Are there any updates? Could you please reach out to me via PM/Email.
Thanks!
I've attached the boot log for the AGFB014R24A2E2VR0 board booting successfully with reduced memory.
The build dates are different, since I had to regenerate the .jic for the QSPI, and the eMMC image had been rebuilt with some unrelated file changes in the rootFS. The U-boot and kernel settings were unchanged.
Thanks!
Yes, there are differences in the steps.
- The ATF steps are skipped
- Buildroot is used to build everything, so toolchain, u-boot, linux, etc
- the steps for building the SD card image are also different. Our image is created using the genimage tool
The memory was reduced by adding the 'mem=3584M' to the u-boot bootargs that get passed to Linux.
I will add the boot log for the AGFB014R24A2E2VR0 board at a later date as I don't have that on hand.
I've attached the boot log for the AGFB014R24B2E3V board booting successfully with reduced memory.
Thanks!
- EBERLAZARE_I_Intel4 years ago
Can you share how did you compile your U-boot and Kernel ?
Also, Is there any different from the steps from the Building Bootloader? If so, please state what is the different steps made:
https://rocketboards.org/foswiki/Documentation/BuildingBootloader#Agilex_45_Boot_from_SD_Card
Additionally, how actually did you reduce the memory and got it to boot up?, (from where, in what environment etc.) when you mentioned "If I reduce the amount of memory available to Linux (passing in up to 'mem=3584M') then the new boards boot as expected."?
Lastly, can you share the success boot logs?
Is there any different when you boot the "AGFB014R24A2E2VR0 Agilex parts" vs a success booting the "new boards with the AGFB014R24B2E3V" when reduce the memory available to Linux?
Or if possible, you can share both success logs here.
I made the changes recommended, and tested it out. The issue was still present. Comparing the differences in the boot logs, nothing stood out to me, but I've attached the file just in case.
Thanks!
You could try using this:
memory {
#size-cells = <2>;
<1 0x80000000 0 0x80000000>; /* 2GB */
