14 years agoRAMB16_S36_S36 conversion
Is there a Altera megafunction similar to the Xilinx RAMB16_S36_S36? I'll also need to declare the initial contents of the RAM.
14 years agoThe Xilinx RAMB16_S36_S36 is a primitive, similar to the Altera altsyncram. You could create something similar with the MegaWizard, but if you want, I've attached a Verilog file equivalent to map the Xilinx primitive into the Altera architecture. Hope this helps.
