10 years ago
Ramb16_s1_s1
Hi to all
I'm tring to use a XILINX design but I don't manage to make a RAMB16_S1_S1 with megawizard.
This is the component :
--- Quote Start ---
component RAMB16_S1_S1 is
port (
CLKA : in std_logic;
ADDRA : in STD_LOGIC_VECTOR (13 downto 0);
DIA : in STD_LOGIC_VECTOR (0 downto 0);
DOA : out STD_LOGIC_VECTOR (0 downto 0);
ENA : in STD_LOGIC;
SSRA : in STD_LOGIC;
WEA : in STD_LOGIC;
CLKB : in std_logic;
ADDRB : in STD_LOGIC_VECTOR (13 downto 0);
DIB : in STD_LOGIC_VECTOR (0 downto 0);
DOB : out STD_LOGIC_VECTOR (0 downto 0);
ENB : in STD_LOGIC;
SSRB : in STD_LOGIC;
WEB : in STD_LOGIC
end component;
--- Quote End ---
    Thanks for your help.
    I've tested this but not work. :confused:
    library IEEE;
    use IEEE.STD_LOGIC_1164.ALL;
    --library UNISIM;
    --use UNISIM.vcomponents.all;
    entity vdp_vram is
        port (
            cpu_clk:        in  STD_LOGIC;
            cpu_WE:        in  STD_LOGIC;
            cpu_A:        in  STD_LOGIC_VECTOR (13 downto 0);
            cpu_D_in:    in  STD_LOGIC_VECTOR (7 downto 0);
            cpu_D_out:    out STD_LOGIC_VECTOR (7 downto 0);
            vdp_clk:         in  STD_LOGIC;
            vdp_A:        in  STD_LOGIC_VECTOR (13 downto 0);
            vdp_D_out:    out STD_LOGIC_VECTOR (7 downto 0));
    end vdp_vram;
    architecture Behavioral of vdp_vram is
        PORT
            aclr_a        : IN STD_LOGIC  := '0';
            aclr_b        : IN STD_LOGIC  := '0';
            address_a        : IN STD_LOGIC_VECTOR (13 DOWNTO 0);
            address_b        : IN STD_LOGIC_VECTOR (13 DOWNTO 0);
            clock_a        : IN STD_LOGIC  := '1';
            clock_b        : IN STD_LOGIC ;
            data_a        : IN STD_LOGIC_VECTOR (0 DOWNTO 0);
            data_b        : IN STD_LOGIC_VECTOR (0 DOWNTO 0);
            enable_a        : IN STD_LOGIC  := '1';
            enable_b        : IN STD_LOGIC  := '1';
            wren_a        : IN STD_LOGIC  := '0';
            wren_b        : IN STD_LOGIC  := '0';
            q_a        : OUT STD_LOGIC_VECTOR (0 DOWNTO 0);
            q_b        : OUT STD_LOGIC_VECTOR (0 DOWNTO 0)
    end component;
    begin
        ram_blocks:
        for b in 0 to 7 generate
        begin
            inst: RAMB16_S1_S1
            port map (
                clock_a    => cpu_clk,
                address_a    => cpu_A,
                data_a    => cpu_D_in(b downto b),
                q_a    => cpu_D_out(b downto b),
                enable_a    => '1',
                aclr_a    => '0',
                wren_a    => cpu_WE,
                clock_b    => not vdp_clk,
                address_b    => vdp_A,
                --data_b    => "0",
                data_b    => "0",
                q_b    => vdp_D_out(b downto b),
                enable_b    => '1',
                aclr_b    => '0',
                wren_b    => '1'
        end generate;
    end Behavioral;
    This is original file :
    library IEEE;
    library UNISIM;
    entity vdp_vram is
        port (
    end vdp_vram;
    begin
        ram_blocks:
        begin
            inst: RAMB16_S1_S1
            port map (
                CLKA    => cpu_clk,
                ADDRA    => cpu_A,
                DIA    => cpu_D_in(b downto b),
                DOA    => cpu_D_out(b downto b),
                ENA    => '1',
                SSRA    => '0',
                WEA    => cpu_WE,
                CLKB    => not vdp_clk,
                ADDRB    => vdp_A,
                DIB    => "0",
                DOB    => vdp_D_out(b downto b),
                ENB    => '1',
                SSRB    => '0',
                WEB    => '0'
        end generate;
    end Behavioral;
    Thanks for your answer.
    I've already tried 'RAM: 2-PORT' but I don't know what is these signals :
    ENA : in STD_LOGIC;
    WEA : in STD_LOGIC; (wren_a I think)
    You need to look for the 'RAM: 2-PORT' IP from the catalog.
    Cheers,
    Alex
