16 years agoQusetion about wm8731
I use a MIC to give a signal into wm8731 throuth the "MICIN" pin,I want to set the sample rate at 8kHz and let the digital audio data output through the "ADCDAT" pin.While I want it output sound through "LHPOUT" pin and "RHPOUT" pin.
How should I configure the wm8731? Which bit do I need to set? Do I need to connect an external crystal? English is not my first language,read the datasheet of wm8731 is difficult for me.Please help me,Thank You!No RepliesBe the first to reply
