14 years agoQuirk with my clocks
I'm building a Binary Game for my final project in Digital Logic and Design and a small portion of this game I'm building uses a countdown timer to show how much time you have left in your round. ...
14 years agoThe problem you have may be creating "ripple clocks". These are bad. A ripple clock is where you use registers in your design to act as a new clock. What you should be creating instead are clock enables.
To create a clock enable structure try:PROCESS(reset, clock)
BEGIN
IF (reset = '1') THEN
counter <= 0;
clock_enable <= '0';
ELSIF (rising_edge(clock)) THEN
IF (counter = counter_limit - 1) THEN
clock_enable <= '1';
counter <= 0;
ELSE
counter <= counter + 1;
END IF;
END IF;
END PROCESS; Aside from that, your code to generate the count down behavior should probably make use of a good synchronous reset. Building a process with an asynchronous reset and a clock enable looks like this: PROCESS(reset, clock)
BEGIN
--put initial conditions here
IF (clock_enable = '1') THEN
--put code here
END IF;
END IF;
END PROCESS;
