17 years agoQuestions regarding interfacing of & accessing custom hardware blocks
Hello, Firstly, before you read the rest - i'm pretty "green" with FPGAs, but i do know how to set up a Nios II soft-core processor system with IP blocks using the SOPC builder, and instantiating ...
16 years ago --- Quote Start --- Hi again, Ok, this really ought to be easy... i guess this is just a case of RTFM, and do it properly.. and then it would occured to me that there is no "magic" tricks regarding the Avalon - there's a address bus - just what i was looking for. Forget my previous post. Now the VHDL code looks like this process regarding the Avalon interface:
process (clk)
begin
if clk'event and clk = '1' then
if reset_n = '0' then
readdata <= (others => '0');
else
if chipselect = '1' then -- our HW is selected
if read = '1' then -- if the HW wants to write to Nios (avalon should read from HW)
if address ="011100" then -- 0x1C (28)
readdata <= branch_cost; -- output this new branch cost.
else
readdata <= "11111111111111111111111111111111"; -- return when nothing has happened.
end if;
end if;
elsif write = '1' then -- if write is asserted (avalon should write to the HW)
case address is
when "000000" => -- 0x00
sys_rec <= writedata;
when "000100" => -- 0x04 (4)
sys_ref <= writedata;
when "001000" => -- 0x08 (8)
par1rec <= writedata;
when "001100" => -- 0x0C (12)
par1ref <= writedata;
when "010000" => -- 0x10 (16)
par2rec <= writedata;
when "010100" => -- 0x14 (20)
par2ref <= writedata;
when "011000" => --0x18 (24)
x <= writedata;
when others =>
null;
end case;
end if;
end if;
end if;
end process;
Regardless of what i'm doing, and even adding a case statement for readdata to read some of the values that are written to the variable/signals... But this does not work - no matter what i do (regardless of using IORD/IOWR and IORD_32DIRECT/IOWR_32DIRECT The code i use is: # include "system.h"# include <io.h>
.# define WR_test(offset,data) IOWR_32DIRECT(BCC_TEST_BASE,offset,data)# define RD_test(offset) IORD_32DIRECT(BCC_TEST_BASE,offset)# define sysref 4
int main(void) {
WR_test(sysref,1);
WR_test(par1ref,3);
printf("sysrech=%x", RD_test(sysref));
printf("sysrecd=%d", RD_test(sysref));
return 0;
I have tried defining sysref as 4 and 0x04, but by the same results No matter what i have done, it always prints that: sysrech=0 and sysrecd=0 My entity of the VHDL is just: entity bcc_test
port (
signal clk,
reset_n,
read,
write,
chipselect : in std_logic;
signal readdata : out std_logic_vector(31 downto 0);
signal writedata : in std_logic_vector(31 downto 0);
signal address : in std_logic_vector(5 downto 0)
end bcc_test;
Any hints? From importing the component in SOPC builder, there were absolutely no errors, and the write and read waveforms also looked as expected. Thanks for any hints regarding why it always throws a zero back... :) --- Quote End --- did find the answer?
