17 years agoQuestions regarding interfacing of & accessing custom hardware blocks
Hello, Firstly, before you read the rest - i'm pretty "green" with FPGAs, but i do know how to set up a Nios II soft-core processor system with IP blocks using the SOPC builder, and instantiating ...
17 years agoAh that is interesting. The spec has changed. My assumption is that they are trying to get people to move away from using chipselect on regular slave interfaces.
However, I have to assume that the interface still behaves to it's original spec. If the component editor allows you to add chipselect as a slave signal, then the fabric knows what to do with it. I normally do not use the chipselect signal as it's provided with "read" and "write". The only time I use it is when I'm actually interfacing to an external IC that needs the signal (even then you could derive it from read and write). Jake
