17 years agoQuestions regarding interfacing of & accessing custom hardware blocks
Hello, Firstly, before you read the rest - i'm pretty "green" with FPGAs, but i do know how to set up a Nios II soft-core processor system with IP blocks using the SOPC builder, and instantiating ...
17 years agoChipselect does exist in Avalon but it is optional. If you use chipselect, you must gate read and write with it. If you don't use chipselect, read and write are only asserted when your component is selected.
