16 years agoQuestion on LE
Dear all, Im wondering if it is possible to have a design that actually has fewer logic gates but took up more LE than another design that has more logic gates? This is happened to my desi...
16 years ago --- Quote Start --- Hi, could you see the zip-file at the end of the post ? Keep attritbute in VHDL : signal net1 : std_logic; attribute keep: boolean; attribute keep of net1: signal is true; Kind regards GPK --- Quote End --- ya, i saw it! thanks alot! In my design, I use functions (written as package) so all the arithmetic involved variables rather than signals. only the input and output are declared as signals. in my case, what should I do to use this keep attribute?
