16 years agoQuestion on LE
Dear all, Im wondering if it is possible to have a design that actually has fewer logic gates but took up more LE than another design that has more logic gates? This is happened to my desi...
16 years ago --- Quote Start --- Hi, ermm..where can I access the attachment? regarding this "keep" attribute. Im still not very sure how it is done. Is is applicable to variable? Regards, Clare --- Quote End --- Hi, could you see the zip-file at the end of the post ? Keep attritbute in VHDL : signal net1 : std_logic; attribute keep: boolean; attribute keep of net1: signal is true; Kind regards GPK
