16 years agoQuestion on LE
Dear all, Im wondering if it is possible to have a design that actually has fewer logic gates but took up more LE than another design that has more logic gates? This is happened to my desi...
16 years ago --- Quote Start --- how is that be done? --- Quote End --- Hi, rbugalho is right, you could also try to use soome synthesis attribute. Example: Verilog wire net1 /* synthesis keep */; VHDL signal net1 : std_logic; attribute keep: boolean; attribute keep of net1: signal is true; Kind regards GPK
