15 years agoQuestion about Monitor
Hello, is it possible to synthesize the "monitors" on the altera fpgas'. There are Monitor IPs such as Avalon MM Monitor. Can I synthesize such "Monitors"?
15 years agoRysc, usually I get timing errors between nodes that are related to the avalon switch fabric. How do I specify the timing constraints related to these nodes before I compile the design. [I will only know the errors after they are compiled] So in this case there is no other option other than specifying the timing exceptions in the sdc after the design right?.
I can specify the timing constraints before compilation, if it's my own design without any Avalon generated components, right?
