14 years agoQuestion about Custom User HDL
Hi, I try to implement a VHDL code as custom user HDL. The component that i need to release is an algorithme that determine the five greatest value for 16 input in one clock cycle. I compile th...
14 years agoThank you for your reply et for this clarification,
--- Quote Start --- Dude make a HDL block with inputs and outputs and your logic. --- Quote End --- I synthetize my HDL block and it work fine. --- Quote Start --- Then integrate it in your SOPC connecting the inputs(data, clock, reset) and outputs(5 highest numbers, maybe a valid signal?) in their respective signals. (take a look at the AVALON INTERFACE/SOPC user guide to see the correct name of the signals). --- Quote End --- And i read AVALON INTERFACE/SOPC "http://www.altera.com/literature/ug/ug_sopc_builder.pdf" but i don't arrived to understand it because isn't simple. If it is possible that you give me a small information or to clarify this. If isn't possible, can your reply to me for the following question: 1- I use avalon memory mapped slave, when i relate each input and output for the following connect i get these two message: warning: avalon_slave_0: signal read data appears 4 times(only once is allowed) error: avalon_slave_0 has write interface but no witre control. what can i do with this message. --- Quote Start --- However the calculus won't be done in one clock cycle, it will take X clock cycles + X clock cycle to perform a read in the NIOS2 (i think the total clock cycle number will be small enough for you.. it will probably take 5~10 clock cycles) --- Quote End --- Thank yoy for this inofrmation.
