14 years agoQuestion about Custom User HDL
Hi, I try to implement a VHDL code as custom user HDL. The component that i need to release is an algorithme that determine the five greatest value for 16 input in one clock cycle. I compile th...
14 years agoDude make a HDL block with inputs and outputs and your logic.
Then integrate it in your SOPC connecting the inputs(data, clock, reset) and outputs(5 highest numbers, maybe a valid signal?) in their respective signals. (take a look at the AVALON INTERFACE/SOPC user guide to see the correct name of the signals). However the calculus won't be done in one clock cycle, it will take X clock cycles + X clock cycle to perform a read in the NIOS2 (i think the total clock cycle number will be small enough for you.. it will probably take 5~10 clock cycles)
