Quartus Programmer detects Agilex 7 AGFA014R24B device as AGFA014R24A
- 6 months ago
Hello Mark,
This is smartVID device, Production unit, not ES unit. I can confirm with the top marking on the device.
Please make sure you set the voltage setup correctly for the device power up successfully.
something like this : https://docs.altera.com/r/docs/683752/current/agilextm-7-fpga-f-series-transceiver-soc-development-kit-user-guide/adding-smartvid-settings-in-quartus-prime-qsf-file
regards,
Farabi
Are you able to try on Quartus 25.1.1? Only use the standalone Quartus Programmer, no need license.
regards,
Farabi
Hello Farabi,
I have tried with Quartus 25.3.1 Programmer. Same result:
This version detects the device as AGFA014R24AR1. (R1 added at the end vs version 25.1.0)
My concern is that there were difference in reference voltage for some pins (1.8V / 1.2V) between ES and production devices. I would like to insure that device I am using is not an ES.
Mark
- FvM6 months ago
Hi Mark,
guessing autodetect might be faulty. Did you try as suggested before?Regards
FrankLoad .sof file for AGFA014R24B and try to program. Can it successfully programmed?
- Farabi_Altera6 months ago
Hello Mark,
regards,
Farabi
