Quartus Programmer detects Agilex 7 AGFA014R24B device as AGFA014R24A
- 6 months ago
Hello Mark,
This is smartVID device, Production unit, not ES unit. I can confirm with the top marking on the device.
Please make sure you set the voltage setup correctly for the device power up successfully.
something like this : https://docs.altera.com/r/docs/683752/current/agilextm-7-fpga-f-series-transceiver-soc-development-kit-user-guide/adding-smartvid-settings-in-quartus-prime-qsf-file
regards,
Farabi
Could you try below?
1- Load .sof file for AGFA014R24B and try to program. Can it successfully programmed?
2- Can you see the part number printed on the FPGA? Is it the printed as AGFA014R24B or else?
3- Please make sure you use latest Quartus version. 25.1.1 and beyond.
regards,
Farabi
- mark_k7 months ago
Thanks Farabi,
- Did not succeed to program it yet. Some issue with Smart VID handshaking with DC/DC. Working on it.
- The number printed on FPGA is AGFA014R24B1E1V:
Quartus version is 25.1.0 (not 25.1.1) with patch 0.36 Could it be the problem?
JTAG IDCODE (detected via Corelis JTAG test) is "1100 0011010000011010 00001101110 1"
which matches AGFA014R24B https://docs.altera.com/r/docs/683748/current/agilextm-7-jtag-boundary-scan-testing-user-guide/agilextm-7-bst-operation-control
Mark
