9 years ago
Quartus Prime Standard 15.1 - Missing Arria 10 compatible IP in Catalog
Hi all,
I have just installed Quartus prime standard 15.1 and am starting a project using an Arria 10 board. I need to use the IP catalog (for PLLs specifically) but there is no IP compatible with the Arria 10 for some reason. The project was previously based on a Cyclone V FPGA on the lite edition but I have changed the device settings. All the other IP for other devices are available. Any ideas as to what's wrong??
Dáire.
1 Reply
    Hello dcanavan,
    Did you install the .QDZ for Arria when you installed quartus ?
    You have to install these libs separately for each family.
    Sometimes boards come with golden reference design examples, there is a directory IP in these examples, if you copy the contents of these directories to your project ip directory (or create one) you can go a long way.
    Johi.
