9 years agoQuartus Prime Standard 15.1 - Missing Arria 10 compatible IP in Catalog
Hi all, I have just installed Quartus prime standard 15.1 and am starting a project using an Arria 10 board. I need to use the IP catalog (for PLLs specifically) but there is no IP compatible w...
9 years agoHello dcanavan,
Did you install the .QDZ for Arria when you installed quartus ? You have to install these libs separately for each family. Sometimes boards come with golden reference design examples, there is a directory IP in these examples, if you copy the contents of these directories to your project ip directory (or create one) you can go a long way. Best regards, Johi.
