Quartus Prime Pro crash-prone
I keep getting this unwanted message:
I am running QPP 18.1 Build 222 09/21/2018 SJ Pro Edition, on windows 10. The crashes seem to occur most frequently when I am running Timing Analyzer.
- Vicky1
Thanks for the additional details.
meanwhile you can check the below solution note,
https://www.intel.com/content/altera-www/global/en_us/index/support/support-resources/knowledge-base/tools/2018/fatal-error--access-violation-at-00007ffb48fdbe10.html
Vicky
- Seadog
I have been getting this crash in or when cross-probing to chip planner, but at least lately I have only been running chip planner after doing a complete build (I am generally just pushing the compile button), as I am chasing timing closure. And I have seen the same (or very similar) behavior in QPS 18.1, QPP 18.1, and QPP 19.2. I know Standard and Pro have different compilers, but I suspect the chip planner and perhaps timing analyzer are the same for both tools. It seems most likely a common feature is causing similar problems in both tools.
- JosephC_Intel
Contributor
Hi Daniel,
From what being share by Vicky on his last comment on the KDB, do this give you a better picture on how to avoid such crash or error?
We do have same issue reported internally but once we put chip planner as last step during compilation, the standard operation instruction should complete.
Let us know if you still need further support or if we are OK to close this issue for now.
Joseph
- JosephC_Intel
Contributor
Hi Daniel,
Can we get some updates here? If further help is required, we can submit this case to engineering.
So, please update us your status.
Joseph
