16 years agoQuartus II Error
Internal Error: Sub-system: SUTIL, File: /quartus/synth/sutil/sutil_device.cpp, Line: 1242
is_legal_device() Stack Trace: 0x286cc: CDB_SGATE_NETLIST::dfs_visit_oterm + 0x55c (db_cdb_sgate) 0x9702: MEM_SEGMENT_INTERNAL::locked_allocate + 0x62 (ccl_mem) End-trace Quartus II Version 9.1 Build 222 10/21/2009 SJ Full Version7 Replies
Thank you for the answer, but I am a beginner and i don't know how to do that. I would be very grateful to you if you could please tell me where should I post my message so that I can get an appropriate answer.
Thank you again :) and have a nice day. - Altera_Forum
you might try a new thread, i'm not sure that's related to the original topic.
I forgot to say that I am using Altera DE2 Board and NIOS II 7.2 IDE.
I am trying to compile a project which can be found at this web site: instruct1.cit.cornell.edu/Courses/ece576/FinalProjects => 2007 => FPGA Paint The problem is that, when I am trying to run NIOS II, I can found system_0.ptf. Could you please help me? Thank you very much and have a good night :) ! - Altera_Forum
which device are you targeting?
did you find the solution ??? i have exactly the same problem... thanks ...
Internal Error: Sub-system: SUTIL, File: /quartus/synth/sutil/sutil_device.cpp, Line: 1242 is_legal_device() Stack Trace: 0x286cc: CDB_SGATE_NETLIST::dfs_visit_oterm + 0x55c (db_cdb_sgate) 0x9702: MEM_SEGMENT_INTERNAL::locked_allocate + 0x62 (ccl_mem) End-trace Quartus II Version 9.1 Build 350 03/24/2010 SJ Web Edition Service Pack Installed: 2 - Altera_Forum
Did you report that to Altera MySupport ?
They will probably need the project that caused this. Quartus menue -> Project -> Archive Project BTW there is SP1 available. Quartus II Version 9.1 Build 30 01/25/2010 SJ Full Version
