10 years ago
Quartus II compilation error message for pll clock fan out
I'm working on a design. After compilation, I got a message as below.
Error: Net "enet_refclk_125MHz", which fans out to "test_clk_1", cannot be assigned more than one value
Error: Net is fed by "altlvds_tx_top:altlvds_tx_top|tx_coreclock"
Error: Net is fed by "pll_125:pll_125|c0"
This is a message for the pll clock fan out. How to fix it?
Thanks you.
Peter
    Hi msj,
    Thanks for your answer. After receiving your comment, I've tried to check my code,
    there was an error that I connected enet_refclk_125MHz to an output port of anther
    module too. The message was misleading me to a problem of the clock fan outs.
    It is solved now.
    Thank you!
    Peter Chang
    It seems that you have fed your clock from two different sources. Feed it by one source or use a clock control core for supplying it with several clocks.
