10 years agoQuartus II compilation error message for pll clock fan out
Hi, I'm working on a design. After compilation, I got a message as below. Error: Net "enet_refclk_125MHz", which fans out to "test_clk_1", cannot be assigned more than one value Error:...
10 years agoHi msj,
Thanks for your answer. After receiving your comment, I've tried to check my code, there was an error that I connected enet_refclk_125MHz to an output port of anther module too. The message was misleading me to a problem of the clock fan outs. It is solved now. Thank you! Peter Chang
