14 years agoQuartus II 11.0 ON Windows XP Error: Current module quartus_map ended unexpectedly
Info: *******************************************************************
Info: Running Quartus II Analysis & Synthesis Info: Version 11.0 Build 157 04/27/2011 SJ Full Version Info: Processing started: Sun Nov 20 00:31:20 2011 Info: Version 11.0 Build 157 04/27/2011 SJ Full Version Info: Processing started: Sun Nov 20 00:31:20 2011 Info: Command: quartus_map --read_settings_files=on --write_settings_files=off decode38 -c decode38 Info: Only one processor detected - disabling parallel compilation Info: Found 1 design units, including 1 entities, in source file decode38.v Info: Found entity 1: decode38 Info: Found entity 1: decode38 Info: Elaborating entity "decode38" for the top level hierarchy Info: Timing-Driven Synthesis is running Info: Generating hard_block partition "hard_block:auto_generated_inst" Info: Implemented 19 device resources after synthesis - the final resource count might be different Info: Implemented 3 input pins Info: Implemented 8 output pins Info: Implemented 8 logic cells Info: Implemented 3 input pins Info: Implemented 8 output pins Info: Implemented 8 logic cells Info: Quartus II Analysis & Synthesis was successful. 0 errors, 0 warnings Info: Peak virtual memory: 247 megabytes Info: Processing ended: Sun Nov 20 00:31:24 2011 Info: Elapsed time: 00:00:04 Info: Total CPU time (on all processors): 00:00:04 Info: Peak virtual memory: 247 megabytes Info: Processing ended: Sun Nov 20 00:31:24 2011 Info: Elapsed time: 00:00:04 Info: Total CPU time (on all processors): 00:00:04 error: current module quartus_map ended unexpectedly6 Replies
--- Quote Start --- multiple versions of Quartus can coexist on the same PC so you're saying decode38 won't synthesize on QII 11.0? --- Quote End --- YES. the error QII gives is "Current module quartus_map ended unexpectedly " but QII9.1 can run well. - Altera_Forum
so you're saying decode38 won't synthesize on QII 11.0? - Altera_Forum
--- Quote Start --- did you try 11.0sp1 or 11.1? you could file a Service Request with Altera or try slimming down the design until it compiles and try to isolate the problem --- Quote End --- I use the Quartus II 9.1 edition to do this simple compiling.It worked well. And just the quartus 11.0 have this BUG.. this is my code,a 38 decoder module: module decode38(data_in,data_out); input[2:0] data_in; output[7:0] data_out; reg[7:0] data_out; always@( data_in ) begin case(data_in) 3'b000:data_out=8'b0000_0001; 3'b001:data_out=8'b0000_0010; 3'b010:data_out=8'b0000_0100; 3'b011:data_out=8'b0000_1000; 3'b100:data_out=8'b0001_0000; 3'b101:data_out=8'b0010_0000; 3'b110:data_out=8'b0100_0000; 3'b111:data_out=8'b1000_0000; endcase end endmodule Maybe the two Editions are not compatible on a PC. Can they be setup at one PC??? THANK YOU A LOT!! - Altera_Forum
you could file a Service Request with Altera or try slimming down the design until it compiles and try to isolate the problem - Altera_Forum
I have to emphase that the OS is Windows XP ..
Many people get the same problem with Linux.... - Altera_Forum
I really can't bear it.
Is there anyone ever came across such problem ??? HELP
