14 years agoQuartus II 11.0 ON Windows XP Error: Current module quartus_map ended unexpectedly
Info: ******************************************************************* Info: Running Quartus II Analysis & Synthesis Info: Version 11.0 Build 157 04/27/2011 SJ Full Version Info: Processi...
14 years ago --- Quote Start --- did you try 11.0sp1 or 11.1? you could file a Service Request with Altera or try slimming down the design until it compiles and try to isolate the problem --- Quote End --- I use the Quartus II 9.1 edition to do this simple compiling.It worked well. And just the quartus 11.0 have this BUG.. this is my code,a 38 decoder module: module decode38(data_in,data_out); input[2:0] data_in; output[7:0] data_out; reg[7:0] data_out; always@( data_in ) begin case(data_in) 3'b000:data_out=8'b0000_0001; 3'b001:data_out=8'b0000_0010; 3'b010:data_out=8'b0000_0100; 3'b011:data_out=8'b0000_1000; 3'b100:data_out=8'b0001_0000; 3'b101:data_out=8'b0010_0000; 3'b110:data_out=8'b0100_0000; 3'b111:data_out=8'b1000_0000; endcase end endmodule Maybe the two Editions are not compatible on a PC. Can they be setup at one PC??? THANK YOU A LOT!!
