14 years agoQuartus II 11.0 ON Windows XP Error: Current module quartus_map ended unexpectedly
Info: ******************************************************************* Info: Running Quartus II Analysis & Synthesis Info: Version 11.0 Build 157 04/27/2011 SJ Full Version Info: Processi...
14 years ago --- Quote Start --- multiple versions of Quartus can coexist on the same PC so you're saying decode38 won't synthesize on QII 11.0? --- Quote End --- YES. the error QII gives is "Current module quartus_map ended unexpectedly " but QII9.1 can run well.
