student8
2 years agoQuartus fails at the Fitter stage, with the following error message. How should I resolve this?"
Error (170143): Final fitting attempt was unsuccessful Info (170138): Failed to route the following 2 signal(s) Info (170139): Signal "tic:tic4|WideOr4~0" Info (170139): Signal "tic:tic6|stop_delt...
student8
2 years agoI found that changing the initial placement seed seems to solve the problem. However, I still want to know how to avoid this issue by modifying the code?
sstrell
2 years agoWhat device is this and what speed are you trying to run at? Do you have a .sdc and are you meeting all timing requirements?
- student82 years ago
Thank you for your reply.
I am using the Cyclone V 5CGXFC5C6F23C6. The code for the SDC file is in the attached file.Although I named it as a 500M clock, I actually reduced the frequency to 400M in practice. This can be seen in the SDC file.
By changing the seed to a specific value, after the compilation passes, there are timing violations.
The setup time violation is about 0.6ns.
