14 years agoQuartus doesnt recognize my FSM as a FSM
Hello guys i have a "problem", i can't see my FSM as a FSM inside quartus state machine view or RTL viewer or whatever, is this a problem? I use two processes, one is combinational and the other i...
14 years agoI changed to a one process FSM and i didnt got recognized also
process (reset_n, sysclk) is
begin
if reset_n = '0' then
state_core <= WAIT_START_CALC;
mean_reg <= (others => '0');
first_time_reg <= '1';
aux_a_reg <= (others => '0');
contador_ph <= 0;
mag_out_reg <= (others => '0');
finish_calc_reg <= '0';
read_counter <= 0;
elsif rising_edge(sysclk) then
case state_core is
when WAIT_START_CALC =>
if start_calc = '1' then
if contador_ph = 31 then
contador_ph <= 0;
state_core <= READY;
else
contador_ph <= contador_ph + 1;
end if;
end if;
when READY =>
if first_time_reg = '1' then
first_time_reg <= '0';
state_core <= SUM_P1;
else
contador_ph <= 0;
else
end if;
end if;
end if;
when SUM_P1 =>
mean_reg <= "00000" & memory_mean(read_counter);
state_core <= SUM_P2;
when SUM_P2 =>
aux_a_reg <= aux_a_reg + mean_reg;
if read_counter = 31 then
state_core <= DONE;
else
read_counter <= read_counter + 1;
end if;
when DONE =>
mag_out_reg <= aux_a_reg(20 downto 5);
read_counter <= 0;
finish_calc_reg <= '1';
when others =>
end case;
end if;
end process;Josyb, could you please post an example of a SM in your style? TYVM i also tried to design my sm as the code guidelines suggests but without sucess
