14 years agoQsys rename
I am building a NiosII system with Qsys. Qsys makes a complete mess with the naming of the connections to the outside of the system. Some are labelled as the were in SOPC Builder (.out_port_from_the_GPO()). Another one is labelled as clk_100 (going to clk_in of clock source named clk_100) The next one is labelled as clkin_240_clk (going to clk_in of second clock source named clk_240) The sram pins seem to be <modulename>_<conduitname>_<signalname>_out And finally the reset_n is just plain wrong, as it expects a positive logic reset signal (on toplevel: .reset_n(!reset_n))
cpu u0 (
.out_port_from_the_GPO(),
.reset_n(),
.clk_100(),
.clkin_240_clk(),
.sram_tcm_address_out(),
.sram_tcm_byteenable_n_out(),
.sram_tcm_read_n_out(),
.sram_tcm_write_n_out(),
.sram_tcm_data_out(),
.sram_tcm_chipselect_n_out()
How can I change this pin naming? Preferrably to names I want to have, if not possible at least correct and consistent? Cheers, Andy3 Replies
Ok, at least the wrongly named reset signal seems to be solved with compiling the same system in Quartus 12.1. Is there a date yet when Qsys leaves the alpha stadium?
I tried your solution, it does not change the pin names, at least not for the clock/reset module. I can change the first part of the SRAM pin names by changing the conduit.
The system inspector says: Name: reset_n Role: reset_n I have checked, rechecked, signal-tapped the reset. It does not change the fact that it's wrong. I have to connect a positive logic reset to the reset_n signal. May this be a problem with Quartus? (v11.1sp2)? - Altera_Forum
IIRC you can change the names by clicking in the "export" column in QSys. As for the reset signal, as long as it says "reset_n" as role in the System Inspector it should be active low, as in SOPC builder.
