14 years agoQsys rename
Hi, I am building a NiosII system with Qsys. Qsys makes a complete mess with the naming of the connections to the outside of the system. Some are labelled as the were in SOPC Builder (.ou...
14 years agoIIRC you can change the names by clicking in the "export" column in QSys. As for the reset signal, as long as it says "reset_n" as role in the System Inspector it should be active low, as in SOPC builder.
