14 years agoQsys rename
Hi, I am building a NiosII system with Qsys. Qsys makes a complete mess with the naming of the connections to the outside of the system. Some are labelled as the were in SOPC Builder (.ou...
14 years agoI tried your solution, it does not change the pin names, at least not for the clock/reset module. I can change the first part of the SRAM pin names by changing the conduit.
The system inspector says: Name: reset_n Role: reset_n I have checked, rechecked, signal-tapped the reset. It does not change the fact that it's wrong. I have to connect a positive logic reset to the reset_n signal. May this be a problem with Quartus? (v11.1sp2)?
