QSPI DDR Interface with Cyclone10LP: Maximum frequency
Thank you very much for your answer and your suggestions. I see the general proposal is to use 1,8V LVCMOS standard on the pins. How much does it penalize using 3V3 LVCMOS standard vs. 1,8V in terms of achiveable frequency?
Hi mfbm ,
"How much does it penalize using 3V3 LVCMOS standard vs. 1,8V in terms of achiveable frequency?"
- Lower voltage I/O standards (e.g., 1.8V LVCMOS) support higher switching frequencies than higher voltage standards (e.g., 3.3V LVCMOS).
- This is due to faster rise and fall times and reduced capacitive charging time at lower voltages.
Adzim
- mfbm6 months ago
Thank you for the answer.
But I still don't understand the benefit of using 1,8V LVCMOS if, according to the datasheet, the maximum Altera is guaranteeing is 200 MHz for both standards: "I/Os using general-purpose I/O standards such as 3.3-, 3.0-, 2.5-, 1.8-, or 1.5-LVTTL/LVCMOS are capable of a typical 200 MHz interfacing frequency with a 10 pF load." Maybe 1,8V standard would support higher frequencies but if this is still not guaranteed by the manufacturer, the limit is still 200 MHz.
Mabel
- AdzimZM_Altera6 months ago
Hi Mabel,
Let's use 200MHz as the limit since it has been mentioned in datasheet.
I think if using higher frequency, there might be some difficulty to meet timing.
Adzim
- AdzimZM_Altera5 months ago
Hi Mabel,
Please let me know if further assistance is needed.Regards,
Adzim
