pulse generation
Hello Forum,
I have an application that requires me to produce 2.5 - 3.5nS pulses from externally generated edges. Our target device is a Cyclone 1C6 and SW Quartus 7.2. In the IOE description it states "there are two paths in the ioe for a combinatorial input to reach the logicarray. each of the two paths can have a different delay. this allows you
adjust delays from the pin to internal le registers that reside in two
different areas of the device. the designer sets the two combinatorial
input delays by selecting different delays for two different paths under
the decrease input delay to internal cells logic option in the quartus ii
software. when the input signal requires two different delays for the
combinatorial input, the input register in the ioe is no longer available." So if I drive a single pin with say a 1uS rep rate signal and I want to produce a narrow pulse on both the rising and falling edges of that 1uS edge, (basically a logic delay edge detector) how does one go about defeating the Quartus tools from optimizing the path delays? We prefer a solution that uses the Graphic/Block editor and assignment tools, as opposed to a VHDL/AHDL methods, but not opposed to the latter. Thanks
Without setting additional timing constraints, no balancing would occur.
to jakobjones (http://www.alteraforum.com/forum/member.php?u=2226), thanks yes I am trying to produce a single pulse and one at 3nS would be perfect. I have been using the solution that FvM suggests with logic cells in the delay path from input pin and other path direct to logic. I was trying to defeat the optimizer from balancing the 2 paths for a little more control.
I will try the code too. I appreciate all your comments. - Altera_Forum
In bdf designs, LOGIGCELL symbols can be used to define delays, that are kept during synthesis. You can try with around ten logic cells.
This violates all kinds of rules and normally I would never do this but here's a shot:
Jakemodule edge_detect( input clk_150, input edge_in, output edge_pulse ); reg edge_in_r; assign edge_pulse = clk_150 & ^edge_in_r; always @(posedge clk_150) edge_in_r <= {edge_in_r,edge_in}; endmodule - Altera_Forum
Could you clarify? Do you need a produce a pulse of a fixed length or pulses of varying length. For example, does it need to sweep from 2.5 to 3.5ns or can it simply consistently generate say a 3.0ns pulse?
Jake
