PS(Passive Serial) configuration with third part Microprocessor
Hi ,
I want to use a third part Microprocessor to help FPGA(cyclone10 GX) Configurate in PS(Passive Serial) mode,but I encounter somes problem.
1. Because, MaxV device have PFL IP on it, PFL can send uncompressed data to FPFA .
So, If I want to use a third part Microprocessor send the configuration data, How can I genarate a correct PS configuration data?
For example, I have to check device and pin options in quartus, before generateing PS configuration data . What options I have to enable ?
2. How should the MCU send data to the FPGA, after programble a correct PS configuration data in Flash ?
- NurAiman_M_Intel
We do not receive any response from you to the previous answer that I have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you
- NurAiman_M_Intel
If using third party microprocessor, you will need to contact their support team to help for this case. We are not able to provide information about third party.
Aiman
- NurAiman_M_Intel
You can refer to Cyclone 10 GX handbook for more information;
Aiman
- KFL
Hi, Aiman
We can know PFL IP help Uncompressed Data , the information come from Figure 13 and 14 in Parallel Flash Loader Intel® FPGA IPUser Guide.
Before genarateing configuration data in .hex , we can do some setting device and pin options in quartus.
But, I don't have PFL IP. Does the setting have to be adjusting ?
For example, there is a option called '' Generate compressed bitstreams'' , if I enable it?
