15 years agoProperly Constraining Inverted Clock with TimeQuest
I have only a limited understanding of TimeQuest and timing requirements in general, so please excuse my ignorance and lack of technical vocabulary on this subject. I have an FPGA sitting betwe...
15 years ago1. Create a RX_PCLK base clock with
create_clock -name RX_PCLKC -period ... [get_ports RX_PCLK] 2. Create a RX_PCLK_virt virtual clock with (create clock) create_clock -name RX_PCLKC_virt -period ... 3. Set your input delay constraints using RX_PCLK_virt and -clockfall set_input_delay -min ... -clock RX_PCLK_virt -clockfall [get_ports ... ] set_input_delay -max ... -clock RX_PCLK_virt -clockfall [get_ports .... ] 4. Create a TX_PCLK derived clock that is the same as TX_PCLK create_generated_clock -name TX_PCLK -source [get_ports RX_PCLK] [get_posts TX_PCLK] 5. Set your output delays relative to TX_PCLK using -clockfall set_output_delay -min ... -clock TX_PCLK -clockfall [get_ports ... ] set_output_delay -max ... -clock TX_PCLK -clockfall [get_ports .... ] 6. Create a generated inverted pixel_clock. create_generated_clock -name pixel_clock -source [get_ports RX_PCLK] -invert [get_nets pixel_clock] However, I think Quartus will recognize this during synthesis and convert all the posedge logic fed by pixel_clock to negedge logic. If it does this, this create_generated_clock is problably unecessary and will problably fail as well.
