Programming older EP910ILC-15 parts
Anyone know which programmers can program the older (just obsoleted about a year ago) Altera EP910ILC-15 parts? Arrow used to program them for us, but no longer want to. And, we have about 500 that we would like programmed. I'm assuming that a .POF file is the file used to program these chips.
Sutton4 Replies
Yes, the information can be found on the Altera website, somewhere in Altera programming hardware docs.
APU is the only off-board programmer that has been available from Altera, so if isn't made anymore, you must use one of the said third-party programmers. Depending on their respective programming socket concecpt, an adapter may be needed. I know, that this has been the case with previous HILO programmers. - Altera_Forum
The APU is obsolete. Anyone know where I can get one? Does any current Altera programmer program EP910ILC-15 parts?
Where did you get that information? On the Altera website, I can't find any mention of that device being supported by the programmer. I assume that you must get an adapter. And, that part is not listed in the adapter section either.
They are supported by Altera Programming Unit (APU) and most third party programmers, e.g. from DATA-I/O or HILO. Most manufacturers have a device search tool to identify compatible programmers for a particular part.
