MK_ABQ
Contributor
3 years agoProgramming non volatile part of Intel Arria 10GX Development kit
Having a basic question on Arria 10 GX Devkit: DK-DEV-10AX115S-A.
We performed d basic testing by programming a sof into the FPGA and controlled few LEDs.
Now we would like the program to s...
NurAiman_M_Intel
3 years agoHi,
Kindly refer below;
You can use the Quartus Programmer to program the flash with your Programmer Object File (.pof).
- Start the Quartus Programmer.
- Click Auto Detect to display the devices in the JTAG chain.
- Select the flash attached to the MAX® V and then click Change File and select the path to the desired .pof. If the flash is not detected, configure the FPGA with any configuration image which does not drive the flash signals and then go to step 2, refer to Configuring the FPGA using Quartus Programmer
- Turn on the Program/Configure option for the added file.
- Click Start to program the selected file to flash. Programming is complete when the progress bar reaches 100%. If flash programming fails, change the TCK frequency to a lower frequency (16 MHz or 6 MHz).
Aiman
