12 years agoProgramming NIOS II code to EPCQ in Quartus 13.1
Hello
I'm having trouble with NIOS II code executing from an EPCQ x4 flash chip (p/n Micron N25Q256A) after a power cycle. I've followed the following guideleins to boot from EPCQ or EPCS (from Altera rd11192013_118): http://www.altera.com.cn/support/kdb/solutions/rd11192013_118.html I have taken the following steps (in order). According to Altera, steps 6-15 would be required *each* time I make a change to either hardware OR software and I want to program to non-volatile memory (i.e. when I do not want a JTAG cable connected to hardware). This is very time consuming. Am I missing something fundamental? 1. Added lines STRATIXV_CONFIGURATION_SCHEME "ACTIVE SERIAL X1" and ENABLE_INIT_DONE_OUTPUT ON to project qsf 2. Deleted db and incremental db in project directory 3. Pointed the reset vector of NIOS to an EPCS/EPCQ controller (connected in Qsys, with a locked base address of 0x00) 4. Pointed the exception vector to on-chip-memory 5. Generated Qsys design 6. Compiled in Quartus II 7. Converted programming file from sof to jic, specified active serial x4, added the correct p/n for the flash loader, and turned on compression (as requested by solution document) 8. Generated a jic 9. Successfully programmed and verified EPCQ 10. Power cycled - I have an LED turn on when the FPGA configures, and this LED turned on 11. Generated flash files for hardware with sof2flash --input=hw.sof --output=hw.flash -epcq --verbose 12. Generated flash file for software with elf2flash --input=sw.elf --output=sw.flash --epcs --after=hw.flash --verbose (this is supposed to be "epcs" even though the chip is "epcq") 13. Used nios2-configure-sof (command line programmer) to configure FPGA with hw.sof 14. programmed the device using the Nios II flash programmer using nios2-flash-programmer --epcs --base=0x00 hw.flash (the epcq needs to be programmed with the .flash file even if it had been programmed with quartus programmer earlier in .jic format) 15. nios2-flash-programmer --epcs --base=0x00 sw.flash I have another blinking LED running in main() in my Nios C code. After running nios2-flash-programmer, the processor enters reset and the LEDs blink. However, after a power cycle, all pins are in tri-state and neither the FPGA nor the Nios processor will configure. Am I missing something?
