12 years agoProgramming NIOS II code to EPCQ in Quartus 13.1
Hello I'm having trouble with NIOS II code executing from an EPCQ x4 flash chip (p/n Micron N25Q256A) after a power cycle. I've followed the following guideleins to boot from EPCQ or EPCS (fro...
11 years agoHi Jens,
Thank you for your description. What the C code in your example? Where and when this is executed? My issue - if I using JIC file and configure EPCQ through the Quartus programmer, fpga is started successfully, but if I use Flash Programmer fpga fabric (not nios) has not started. I'm following the solution http://www.altera.com/support/kdb/solutions/rd11192013_118.html but not succsefull
