Programming failing in DE10-Nano board (And in my board as well)
It seems that the flash device actually on board is EMCS64. (However, on the DE10nano design scheme, they put S25FL128.)
After updating the flash device, The following messages were: (See snapshot above as well)
Info (209060): Started Programmer operation at Tue Dec 31 09:44:49 2024
Info (209016): Configuring device index 2
Info (209017): Device 2 contains JTAG ID code 0x02D020DD
Error (209040): Can't access JTAG chain
Error (209014): CONF_DONE pin failed to go high in device 2. Make sure all communication cables are securely connected, select a different device, check the power on the target system, or make sure all nCE pins are connected to GND. The Intel FPGA Knowledge Database contains many articles with specific details on how to resolve this error. Visit the Knowledge Database at https://www.altera.com/support/support-resources/knowledge-base/search.html and search for this specific error message number.
Error (209012): Operation failed
Info (209061): Ended Programmer operation at Tue Dec 31 09:44:59 2024
- BXia1 year ago
Hi, it seemed that you even didn't add .jic file based on your screenshots.
You'd better follow the steps in section 8.3 Write jic file into the EPCS device of DE10-Nano user manual to program .jic file.
