Sho2301's avatar
Sho2301
2 years ago
Programming external QSPI Flash with PFL IP on MAX 10 FPGA
I am trying to boot the Nios 2 softcore processor from a external QSPI flash. I have followed all the steps detailed in the Embedded Developers Handbook Nios 2 from page 276 onwards but had a problem with the step where i was supposed to programm the .pof file converted from .hex file, containing the nios 2 application code, into the external qspi flash with Parallel Flash Loader. As the first i flashed the image containing the PFL into the FPGA. According to the Embedded Developers Handbook the QSPI Flash should then be recognized in the JTAG Chain if i hit the auto detect button in the quartus programmer, which isn't the case in my implementation. I've also tried to manually add the flash device into the JTAG chain via the attach flash file sub menu but am getting the error: "209012 Operation failed" which indicates that the flash device is not found.
The Max 10 i'm using is the 10M08SAU169I7G and the external flash is the Micron MT25QL256ABA8ESF in the 256Mb variant which should be supported by the PFL according to the Intel documentation.
https://www.intel.com/content/www/us/en/support/programmable/articles/000074565.html?wapkw=mt25q
I've attached my PFL project and would greatly appreciate some help on this matter.
Best regards
  • tehjingy_Altera's avatar
    tehjingy_Altera
    Hi
    Jingyang, Teh
    tehjingy_Altera
    Hi
    I am Jingyang and will be helping you out in this case.
    Have you tried flashing the sof only to see if you are able to see the nios core in the jtag chain?
    Jingyang, Teh
