16 years agoProgramming EPC1441 with USB Blaster
Hello. Anybody knows if it is possible to program EPC1441 with usb blaster anyway?. Depending on different datasheets it seems it´s possible using .sof in passive serial mode. But in other d...
16 years agobolitary (http://www.alteraforum.com/forum/member.php?u=27618) , have you found the answer? The datasheet is written so, that it is not easy to figure out how to program that epc1441. I am having the same problem as you had a month ago...
