16 years agoProgramming EPC1441 with USB Blaster
Hello. Anybody knows if it is possible to program EPC1441 with usb blaster anyway?. Depending on different datasheets it seems it´s possible using .sof in passive serial mode. But in other d...
16 years agoSeriously, you can't expect to find the answer in the USB-Blaster datasheet (although the latter shouldn't contain misleading information, which is apparently the case).
As I said, there is a datasheet valid for EPC1441, as stated in the Configuration Manual. See http://www.altera.com/literature/hb/cfg/cfg_cf52004.pdf. It only mentions Altera Programming Unit (APU) with respective adapters and third party programmer to program the device. In any case, it's one-time-programmable only.
